Hello !
I have a problem with categories in works. When I set a category as parent, and an other category as child (both have works in them), it doesn't scroll down in the works menu (works home page). The child category doesn't appear anywhere.
Thank you for your help !
Sophie
Could you send me a link to the page where it happens? Maybe there is some JavaScript error happening.
Thanks for the access. This is as intended. The "works list" page lists only top-level categories. When you will view subcategory, you will see those works https://yoursite.com/formation-blog-professionnel/work_genre/ecriture/
I am not sure how to understand this part. Could you explain it in other words?
Thank you for looking at this.
So, I don't understand : I can't see my child category anywhere ?
I wish I could see it in a scroll down menu like this image : https://d2r1vs3d9006ap.cloudfront.net/s3_images/1082423/RackMultipart20140730-29237-1qyvhd5-capturescrollingdropdown_inline.png?1406752467
You said "When you will view subcategory", but this is the point : I don't see it anywhere...
Thanks for your help !
If you want to add it to the main menu you can always do it as explained here
https://rifetheme.com/help/docs/basic-setup/menus/enabling-custom-post-types-in-menu/ You can see it here https://www.contentologue.com/formation-blog-professionnel/work_genre/ecriture/
Or by going to your main works list page, and clicking on the category and opening it with a new tab, or by adding link to that category in the menu as explained above :-)
Hope that helps somehow :-)
Thank you,
Sophie
Now I get that I can add all types of categories in a menu, but to the works menu ?
If I create a new menu with works categories, how can I make it replacing the works menu ? When I go to personnalisation > works list, I don't see any place where I can set my own menu.
Did I miss something again ?
Thank you
Set your own menu? Do you mean like replacing the main menu only for the works list page? Or you want to change something else?
Please mark on the screenshot what you would like to replace.
Thank you
Now it is clear :-) We are talking about filter of categories.
This is generated automatically, so you can not add there anything manually.
It only lists categores on the same level, so unfortunately I don't have any solution for you, but only to make all categoreies at the same level, if you want all of them to be listed.
Too bad, I wished it has this drop down functions, it would look good !
Thank you for your help,
Sophie
