Incorrect display since update
edited November 2019 in Rife Posts: 36
since the last update I have problems with the display.
And fonts are shown bold in places, although I haven't changed anything about it.
My plugins, Theme and Wordpress are all up to date.
Why is that now? :-(
Thanks for the help!
Best regards from Germany!
Link: https://www.blickfrisch-design.de/
Post edited by mindkicks on
    mindkicks said: since the last update I have problems with the display.
    Update of what? Elementor, theme, WordPress?
    mindkicks said: And fonts are shown bold in places, although I haven't changed anything about it.
    I have been on your website and this font from the screenshot is not bold.
    Please be sure to clear cache in plugins that you use(Autooptimize) and in the broswer.
    You can also check in private mode of your browser, to be sure if this isn't the type of issue that you only see when you are logged into WordPress.
  • Hi :-),
    since the update of Wordpress & Theme.
    The font is no longer bold because I changed the last two blocks tonight.
    But if I put the block "Kundenstimmen" under the block "Überflieger statt..." the font becomes bold again.
    I didn't know that with the private mode yet, I will test times. The Chache is actually emptied.
    Thanks for the (once again) fast and competent help! :-)
    mindkicks said: But if I put the block "Kundenstimmen" under the block "Überflieger statt..." the font becomes bold again.
    This sounds like some not closed markup. And indeed now I see in the source code that you have open tag <b> at end of the block "Überflieger statt...".
    Remove it and it will fine :-)
  • Oh, really?! Okay?
    I'll do that and try it out.
    Thank you very much! :-)
