Hi! I have wp recipe maker widget on my site. Unfortunately the collection widget where it puts all saved recipes to one page does not work with rife pro theme. I have tested all and the problem is with the theme. I had this message: Looks like there is a JavaScript error breaking things when trying to load that page.
What can I do to fix th eproblem?
Could you add a screenshot of the situation when it breaks?
I believe I will have to log in to your installation as well to check it.
Please send me temporary* access to your WordPress so I could check there what is going on. Send it here on the forum via private message(click on my nick, in top-right corner you will find option "Message"). In message please add LINK to topic it applies to.
Thanks for the access.
A plugin that you are using was doing something unusual with anchors, and that caused JavaScript crash. I have now added an exception for such situations, and updated code on your website, so it works :-)
The same fix will come with the next theme update. Thanks for the help with debugging this.
