fatmoon sliderrevolution with sidemenu
I am trying to get some sliderrevolutionsliders into the sidemenu layout.
But it always shows up over the complete screen.I tried every option in rowsettings wp bakery and slider revolution. i cant get it running in the sidemenu grid.
Has someone a solution for this?
    Could you show a live link to page where we can see what is your result? Then it will be much easier to advise.
    Yes,here is the link
    http://s261716844.online.de/reel/
    thanks
    The Problem is not solved.Could you please answer my question.
    Please send me temporary access to your WordPress admin panel. I'll try to do my best to solve your problem but I'm not able to just write the answer here because I need to play with the settings.
    P.S Don't forget to send me access via private message. Just click on my name and you will see "Message" button.
    Best regards,
    Lead Graphic Designer
