Hey Folks!
During March of 2020, and possibly April, answers may be delayed more than it usually happens. This is caused by my personal situation that requires a lot of time from me to be dedicated elsewhere, and also because of the local things that are happening currently cause of the all things connected to "Corona Virus".
Please be patient, all answers are coming as soon as possible, even if I have to stay late at night :-)
Sorry for any inconvenience.
Air.
Post options
in Rife Posts: 118
Hi !
I am trying to change a post (no sidebar) in post options or customising, but I can't find it anymore...
Where can I do this now ? I looked in documentation but can't find anything neither.
Thank you !
Sophie
    Hey Sophie :-)
    Post options appear while editing post in classic way, not using Elementor or any other page builder. You should see them at bottom of the edit screen. See this screenshot:
    1740 x 934 - 68K
  • Hi,
    Yes, I'm in classic editor, but on this options, I can't make the post without any sidebar (if I choose "header" tab, and set sidebar as "off", nothing happens.
    But it's ok, I will make my post a page instead. If you have any idea though, I'm interested.
    Thank you !
    Sophie
    Hey:-)
    To disable sidebar in posts go to Customizing ▸ Blog settings ▸Single post ▸Sidebar.
    The option that you were tried to change is for vertical header, that you are not using ;-)
  • So there isn't any option to change it in a specific post right ?
    Hey Sophie.
    There is no option to do it from theme options.
    However, with this code, you can do it from a child theme.
    Add this to functions.php in the child theme, at end of the file
    add_filter('a13_options_post_sidebar', function( $value ){
        $ids_to_exclude = array('6670', '6671', '660');
        if( in_array(get_the_ID(), $ids_to_exclude) ){
            return 'off';
        return $value;
    You can edit IDs in $ids_to_exclude = array('6670', '6671', '660'); and enter IDs of posts you want to not have sidebar.
    I hope that helps.
  • Thank you very much ! :)
