Post options
Hi !
I am trying to change a post (no sidebar) in post options or customising, but I can't find it anymore...
Where can I do this now ? I looked in documentation but can't find anything neither.
Thank you !
Sophie
    Hey Sophie :-)
    Post options appear while editing post in classic way, not using Elementor or any other page builder. You should see them at bottom of the edit screen. See this screenshot:
    1740 x 934 - 68K
  • Hi,
    Yes, I'm in classic editor, but on this options, I can't make the post without any sidebar (if I choose "header" tab, and set sidebar as "off", nothing happens.
    But it's ok, I will make my post a page instead. If you have any idea though, I'm interested.
    Thank you !
    Sophie
    Hey:-)
    To disable sidebar in posts go to Customizing ▸ Blog settings ▸Single post ▸Sidebar.
    The option that you were tried to change is for vertical header, that you are not using ;-)
  • So there isn't any option to change it in a specific post right ?
    Hey Sophie.
    There is no option to do it from theme options.
    However, with this code, you can do it from a child theme.
    Add this to functions.php in the child theme, at end of the file
    add_filter('a13_options_post_sidebar', function( $value ){
        $ids_to_exclude = array('6670', '6671', '660');
        if( in_array(get_the_ID(), $ids_to_exclude) ){
            return 'off';
        return $value;
    You can edit IDs in $ids_to_exclude = array('6670', '6671', '660'); and enter IDs of posts you want to not have sidebar.
    I hope that helps.
  • Thank you very much ! :)
