I am trying to adjust settings (
https://snipboard.io/4cl1JD.jpg) for the works media on this work item:
http://wordalchemists.co.uk/#a13lightbox-work-10662 which appears at the top of the page. For some reason it is enormous but isnt actually showing the full length of the image (full size image is attached). Also, it doesnt open in lightbox when clicked
None of the settings make any difference to how the image at the top of the page displays. Even if i select 'do not display it' it still displays.
What i want to achieve, is to have the image display small and open full size in a lightbox when clicked.
Please help!
If works are opened in the classic way, like here http://wordalchemists.co.uk/work/braun-watch/ you could set the display of media to bricks, set it to 1 column, and then you will have one big image opened to the lightbox.
To enable opening works in a classic way go to Appearance → Customize → Works Settings → Works list → How to open work → Normal.
