Discussions
Categories
Home
FatMoon
pagina blog sparita
serviziweb
February 2020
in
FatMoon
Di colpo non troviamo più la pagina blog originale del tema.
Dal menu principale dava prima errore 404
Poi adesso una pagina bianca
Unica cosa che ho fatto è stato disabilitare elementor
Aiuto! Come faccio a ripristinarla?
sito www.pevacreative.it
serviziweb
February 2020
adesso ho riabilitato il blog con un widget (post masonry grid) ma volevo ripristinare quello originale, mi sapete aiutare?
Air
February 2020
Please write in English as explained here
https://support.apollo13.eu/discussion/12/before-you-ask-read-this-#Item_1
Also, FatMoon theme doesn't use Elemenetor so it doesn't seem it is connected. Maybe some other plugins affects your situation.
For me Blog on your website seems working fine, so maybe it is cache issue. Are you using any cache plugins?
serviziweb
February 2020
Good morning,
sorry here I am in English,
I try to explain myself better:
- BLOG page gave error 304
-Elementor uninstalled (I guess he was the problem)
-The BLOG page was empty
-I used Bakery Page> Post Masonry Grid and I got what you see now
- I no longer have the left sidebar with widgets, can you help me with this?
Air
February 2020
Hey:-)
Here is explained how to set up your blog page
https://rifetheme.com/apollo13-framework/docs/basic-setup/front-page/
If you will not be successful with it, I will try to login to your page and do it for you.
Sign In
or
Register
to comment.
Sign In
Register
Quick Links
Categories
Recent Discussions
Categories
3.7K
All Categories
114
OneLander
324
PhotoProof
590
Rife
40
Agency
130
Starter
886
FatMoon
197
Thirteen
337
Photon
319
Chillout
769
Hypershot
3
General
February 2020
Air
February 2020
serviziweb
Discussions
Categories
Sign In
Please write in English as explained here https://support.apollo13.eu/discussion/12/before-you-ask-read-this-#Item_1
Here is explained how to set up your blog page https://rifetheme.com/apollo13-framework/docs/basic-setup/front-page/
