pagina blog sparita
Di colpo non troviamo più la pagina blog originale del tema.
Dal menu principale dava prima errore 404
Poi adesso una pagina bianca
Unica cosa che ho fatto è stato disabilitare elementor
Aiuto! Come faccio a ripristinarla?
sito www.pevacreative.it
  • adesso ho riabilitato il blog con un widget (post masonry grid) ma volevo ripristinare quello originale, mi sapete aiutare?
    Please write in English as explained here https://support.apollo13.eu/discussion/12/before-you-ask-read-this-#Item_1
    Also, FatMoon theme doesn't use Elemenetor so it doesn't seem it is connected. Maybe some other plugins affects your situation.
    For me Blog on your website seems working fine, so maybe it is cache issue. Are you using any cache plugins?
  • Good morning,
    sorry here I am in English,
    I try to explain myself better:
    - BLOG page gave error 304
    -Elementor uninstalled (I guess he was the problem)
    -The BLOG page was empty
    -I used Bakery Page> Post Masonry Grid and I got what you see now
    - I no longer have the left sidebar with widgets, can you help me with this?
    Hey:-)
    Here is explained how to set up your blog page https://rifetheme.com/apollo13-framework/docs/basic-setup/front-page/
    If you will not be successful with it, I will try to login to your page and do it for you.
