Hello!
I would like to make the following changes on my menu
HEADER MENU
1. I would like to add a drop down option for the blog menu, that would be BLOG> photos sessions, Tips&Tricks, Editorial
2. In my older version the menu of the main pages (about, blog, portfolio) was transparent on top of the content( instead of on a white background) I can’t get that to work anymore
3. in the hamburger version I would like everything to be bigger, like new designs are doing (view example here:
https://rafalbojar.com/)
FOOTER MENU
1. I would like to change the font styles, mainly ABOUT, BLOG, PORTFOLIO, CONTACT should be bold
thank you so much for your help!
2. Enable adding Categories to the menu in the Screen options https://rifetheme.com/apollo13-framework/docs/basic-setup/menus/enabling-custom-post-types-in-menu/
3. Arrange your menu into submenus by drag & drop :-)
You have to mix 2 things to achieve this:
1. Enable in page options: Header → Hide content under the header → Yes, hide the content.
2. Select in the same options header color variant that is transparent or semi-transparent https://rifetheme.com/apollo13-framework/docs/customizing-the-theme/header/variant-light-dark-overwrites/
Do you want a bigger font size there? I believe we will have to do it by custom CSS, just let me know is this what you are looking for.
Please add such custom CSS: With kind regards.
thanks for your help...i managed to fix everything except for the submenu....
i cant find the add categories section... i have the subcategories in my menu but it does not show it!
On your screenshot on the left, there is "Categories" panel - you can add your blog/post categories from there.
If this is not what you are looking for, then please add more details.
"works" should show the sub-sections
| E d i t o r i a l |
| F a m i l y - S e s s i o n s |
| T i p s - & - T r i c k s |
but it does not seem to be working.
