Show different images for posts and listings
in FatMoon Posts: 3
I would like to place a background image in the header of the works other than the one that appears in the list of works. Is this possible to do?
I attach 2 screenshots to make me understand better. I hope it helps!
Thank you!
    Not sure if in this work you have set global setting for the title bar but if yes go to Appearance → Customize → Works Settings → Single work – title bar
    If this is not the case, then you can change it in works options while you edit your single work https://rifetheme.com/apollo13-framework/docs/content-management/albums-works-post-types/album-options/
    Thanks a lot for your response!
    But I think it doesn't work ... because the last option you show me, I can't find it in the wordpress ... However, I have discovered, that I can hide the image with color.
    I leave a capture where it can be seen: D!
    Thank you! Regards!
    936 x 460 - 50K
    Image used in the background of the title bar is featured image that you set on the right, under the "publish" button.
    Adding Featured image
