Theme Scroller
I'm in need of your superpowers again. How can I increase the wide of the overall theme scoller to take advantage of edge to edge?
Right now I'm getting the result attached to this discussion topic.
Also when the image opens up it does not fit in the windows.
    Also hope your staff is well and please stay safe.
    Could you send me a live link, so I could check whare the margins are coming from?
    I actually changed it found a better one...
    but I did this I put this opaque thing on the images and also, how can I move the menu and logo to the top? And how do I shrink the border around each menu?
    The website is https://www.maicolheadshots.com/staging
    2562 x 2354 - 7M
    228 x 416 - 34K
    2526 x 470 - 1M
  • edited March 2020 Posts: 28
    This version of the template seems to work best.
    Post edited by Maicol on
    sorry to be a pain with all these questions. The site is https://www.maicolheadshots.com/staging
    1. So on image 1 how do I get the images to be the full image under the top heading?
    2. Alson the first image how do I get rid of that white opaque border from the faces?
    3. On the bottom footer how do I make the text white and the heading white?
    Sorry about all this bombarding of questions. Though on a positive my colleague is buying the theme, due to how great the support is and also I'll be using the theme on my other site, once I get this one running
    2554 x 2444 - 6M
    2474 x 736 - 100K
    Okay managed to resolve items 1 and 2, but now I get this faint line over the top. See attached image. It's faint but it's there no matter what screen I bring it up on.
    website: https://www.maicolheadshots.com/staging
    661 x 72 - 41K
    Hey there:-)
    Maicol said: Okay managed to resolve items 1 and 2, but now I get this faint line over the top
    This is the header shadow. You can disable it Appearance → Customize → Header Settings → Type, variant, background → Shadow
    Maicol said: 3. On the bottom footer how do I make the text white and the heading white?
    It seems you have solved this as well, right?
    Maicol said: website: https://www.maicolheadshots.com/staging
    This doesn't work for me, so it seems you have moved all changes to the main website?:-)
    Hi Air,
    The variant, background had the shadow turned off already, but you lead me in the right direction. I had turned it on on variant light - override normal setting, turned it off there and it went away. Thank you, you are a genius.
    The color white I coded it to white, only way I can get it to work.
    Oh sorry I've already started working on the next design changes and did a pull from prod to replace staging and have a new staging site.
    Thank you for all the great help.
    Maicol said: Thank you, you are a genius.
    In this case you are a Genius! :-)
    Maicol said: The color white I coded it to white, only way I can get it to work.
    If none of the settings helped with that, then I think it was the same solution that I would advise. Nice one:-)
