I'm in need of your superpowers again. How can I increase the wide of the overall theme scoller to take advantage of edge to edge?
Right now I'm getting the result attached to this discussion topic.
Also when the image opens up it does not fit in the windows.
Could you send me a live link, so I could check whare the margins are coming from?
but I did this I put this opaque thing on the images and also, how can I move the menu and logo to the top? And how do I shrink the border around each menu?
The website is https://www.maicolheadshots.com/staging
1. So on image 1 how do I get the images to be the full image under the top heading?
2. Alson the first image how do I get rid of that white opaque border from the faces?
3. On the bottom footer how do I make the text white and the heading white?
Sorry about all this bombarding of questions. Though on a positive my colleague is buying the theme, due to how great the support is and also I'll be using the theme on my other site, once I get this one running
website: https://www.maicolheadshots.com/staging
This is the header shadow. You can disable it Appearance → Customize → Header Settings → Type, variant, background → Shadow
It seems you have solved this as well, right?
This doesn't work for me, so it seems you have moved all changes to the main website?:-)
The variant, background had the shadow turned off already, but you lead me in the right direction. I had turned it on on variant light - override normal setting, turned it off there and it went away. Thank you, you are a genius.
The color white I coded it to white, only way I can get it to work.
Oh sorry I've already started working on the next design changes and did a pull from prod to replace staging and have a new staging site.
Thank you for all the great help.
If none of the settings helped with that, then I think it was the same solution that I would advise. Nice one:-)
