Good morning,
I'm using the RIFE PRO theme, I'd like to duplicate the About page to make a variation of it but with a different image for each duplicated page. I can't do it, because the image is in the general customization of the theme, resulting in each page duplicated from About to the same visual.
Thanks in advance,
You can change this image on each page by changing background behind the section in the Elementor. You can change it as explained here https://apollo13themes.com/basic-elementor-plugin-tricks/#parallax
