Hi Air
It's been a while! Lately I had no problems with your theme.. but now I have (a small) issue..
the mobile menu conten need to be a little further down as it almost touches the site logo... I tried some css but for some reason I didn't find the solution
See the attached image to understand what I mean ("Herbst/Winter..." should be some pixels further down
Pascal
You could try to increase it with such custom CSS: With kind regards.
Thanks.. unfortunately this didn't change anything... maybe I got something wrong?
Here the test site for you to look at: https://nikatrade.dellamae.ch/
Let me know if you need admin access
Thanks Pascal
In your case proper CSS will be:
You can see the result in the same link now. Sorry for the inconvenience
Remove the whole CSS I gave previously, and add this one: Hope this one will be it :-D
WIth kind regards.
Thanks a lot
Cheers, Pascal
Your CSS did the trick! BUT I'm having a "new" issue when using a background color in the mobile menu.. while the menu text is now correctly placed the background (used on certain pages) is placed over the site logo (see screenshot).. is there a way the have the mobile menu background below the logo? Here's the link: https://nikatrade.dellamae.ch/kollektionen/
Please try this custom CSS: With kind regards.
