Another one for you Elementor allows the integration of Adobe Fonts through API ... but it seems that the actived fonts do not appear in your theme customizer... Can you help? Thanks, Pascal
Thanks for the workaround. But it would be great to have an integration in the theme as it is in Elementor too. And not having to install even more plugins ...
Yes, our fonts are not connected to the Elementor. I will take a look at this integration, and see if we can use it somehow in the theme.
However, please follow this https://rifetheme.com/help/docs/customizing-the-theme/general-settings/fonts-settings/#using-typekit-webfonts
Thanks, Pascal
