Hi Air and Dan,
A friend wants me to design a page along similar lines to this one but with a Works/Portfolio page instead of the Shop page:
http://www.samanthawhite.co.uk/I was thinking of using the January theme but wanted to know if you had any other suggestions that you feel would work better for interior design and architecture?
Thanks so much!
Heather
Yes, you're right, the January design will be the best in this situation.
You can also change the top header to look almost the same as your example from the link. Just switch the proper setting in the customizer.
If your friend is familiar with Elementor he can build almost everything
Best regards,
Hope you're all well. I can't believe it's only been one week of lockdown, feels like longer. But glad to see you on here! Heather
Heather
Are you looking for a horizontal or vertical header?
For horizontal go to: Appearance → Customize → Header Settings → Type, variant, background → Variant
https://rifetheme.com/help/docs/customizing-the-theme/header/type-variant-background/
