Problem in responsive mobile mode in products shop
edited June 2020 in FatMoon Posts: 19
Hi.
I contact you because I have detected a mobile responsive problem in the shop individual products.
I added you a captured images to show you the thing I need to fix.
The URL is https://imagingfactory.es/product/bebe-ninos/
That's all, I'll be waiting you response.
Regards¡.
    This was fixed in the latest update. Please update the theme.
    Important
    Please remove this account you have provided login info to. Remove it as fast as possible or change your password. Please don't ever give your access data if you are not asked for it. Especially please don't post it on public topic. Anyone can access it and destroy it right away. If we need your login data we will especially ask you for it, to send it to us via private message.
  • Ok, thank you. I have change my password.
    Regards.
