Hi!
I´m trying to find how I can add a button in the right upper corner like you did it here:
https://apollo13themes.com/seven-demos-proving-rife-free-is-multipurpose/ (... the "TRY RIFE!" button)
I´m aware of the option described here:
http://rifetheme.com/help/docs/customizing-the-theme/header/tools-icons/ But this options is not as "sexy" as the option on your website.
Looking forward to hear from you! :-)
Thanks,
Tim
Thanks for your kind words! I can share with you our custom CSS, that makes this button look like this: Add it, and your button will look the same :-)
Rest is set in settings that you have mentioned.
