Hi, I have a bug with Rife Free. It’s stop working with Elementor. I install actualization of Yeast Seo, Happy Elementor Addons, WooCommerce Google Analytics Integration. After that it s happen problem with Elementor and I find that it s Rife Free. (in switch off all plugins and i past to theme Twenty Twenty).
The problem is on the pages:
https://www.fizjoekspertka.pl/kursy/https://www.fizjoekspertka.pl/kurs-modul-1/ - here with all 7 pages wich moduls of course
Help me fast, please
I see these 2 pages that you have linked, but what exactly is the problem with Elementor there?
You can not edit them with Elementor any longer?
If yes, I will have to take a look at it in your admin panel.
As for https://www.fizjoekspertka.pl/kursy/ - it is the shop page from WooCommerce and this page is just not editable in Elementor, because it is kind of relict from that times when there were no page builder for WordPress.
You can recreate similar page as a normal page using Elementor widgets.
I think that in Elementor Pro, there is also the option to override the whole template for shop page, even when they are not editable. I believe that this link should be good start https://docs.elementor.com/article/373-creating-a-woocommerce-archive-template-with-elementor-pro
These are 2 solutions that sounds very similar, but you will have to decide which would be better for you.
As for this page https://www.fizjoekspertka.pl/kurs-modul-1/ - if you will enter password to this, and after this try to edit it in Elementor, it works fine.
Hope this will help you!
