Main manu issue in blog page:
https://www.swingdanceshoes.it/suolablake/I don't know how set the main menu in the blog page.
I had set the anchor point of the menu in the main page, and it works perfectly, but when you change the page, you can see the menu but is useless because there are not the anchor point in the page.
How I can set that if I click a voice in the menu you can return to see the main page?
For now the only way to go back in the main page is to click on the logo and is not good see the useless voices in the menu.
In wordpress I see only one dashboard to change the menu options, so I don't know if this is a wordpress issue or a theme issue.
Thank you very much for the help
Mattia
Here is explained how you should make your anchors https://rifetheme.com/apollo13-framework/docs/basic-setup/menus/creating-one-page-menu/#adding-anchors-in-menu
Generally, they should be made as an absolute links, so instead of making links just
#home
make ithttps://www.swingdanceshoes.it/#home
.With kind regards.
Now with all the url, works perfectly!
