.post-media + .title-bar.inside { margin-top: 20px; margin-bottom: 20px; }
Could you show me a link to a page where it happens? Hard to tell what do you mean.
If it is the title bar, then you can reduce padding on the title bar box in title bar settings.
It looks like title bar, however, without link it is hard to tell which setting it will be.
Is it for blog, single post, or static page?
It can be also that only custom CSS will be able to change it. I need live link :-) Or at least bigger screenshot.
Please try this custom CSS: With kind regards.
thank you very much
