Theme options
We have no access to the theme options. What can we do now?
  • https://www.ausgefuxt.ch/fux_new/
    Ask for an urgent answer.
  • edited October 2020 Posts: 5
    We cannot find the theme options...
    327 x 295 - 33K
    Post edited by anziehend on
    edited October 2020 Posts: 10,970
    The "Theme options" panels are a long time banned from the themes that are sold on the ThemeForest. :-)
    All of theme options are available in the WordPress Customizer -> https://rifetheme.com/apollo13-framework/docs/customizing-the-theme/how-to-use-customizer/
    Hope that helps :-)
    Hello
    And it is precisely this customizer that we cannot access. Of course we understand with the answer and the size of the team. ;-)
    Best regards
    Lars
    Please reply on the forum next time :-)
    I see a link to the Customizer on your screenshot from the admin panel. What happens when you click it?
    With kind regards
  • Nothing...
    340 x 529 - 14K
    Thanks for the access. The issue was caused by the plugin "Customify". I have deactivated it and everything works fine now.
  • Perfect! Thank you so much.
