Hi. Dan and Air,
People keep telling me my site looks really old-fashioned because of the side-bar. I'm using Caroline - is there a way I can easily change the sidebar so it's at the top? If not, how do I change the design to another which does have a top bar menu?
I can't find a search option in the Discussions to see if anyone has asked this before...
Thanks! Heather
You can switch the header here: https://nimb.ws/vu7rxs
Best regards,
So sorry but that link doesn't seem to work - I got a 502 bad gateway error message?
Was it a page in the documentation? If so what should I search for to see it?
Heather
Now it should be better
Please check the attachment.
Best,
Maybe you have to disable header color variants before you will get a hang of it: https://rifetheme.com/help/docs/customizing-the-theme/header/variant-light-dark-overwrites/
Let me know more details, and I will help as best I can :-)
