Jennyholdway said: I have downloaded the rife file. It is not a Zip file
Sorry to hear that you are facing such issues.
It have to be ZIP file, if it isn't then it is probably some error.
Please try again downloading the theme from the link that you get in the license e-mail : https://rifetheme.com/help/docs/getting-started/where-i-can-find-license-code/
If you will still have problems with it(it will not be a ZIP file) I will try to do it for you.
Please let me know how it went.
