I’ve created a menu using horizontal header. Upon changing that to vertical header, its sorting changes (by hands of ghosts?) to alphabetical sorting instead keeping my (for good causal reasons) applied manual sorting.
I don't see it on your page currently, as you are using a horizontal header, so it will be hard to guess. I have just checked on our demo https://rifetheme.com/peeky/ and it works normally.
Could you share a screenshot of how does it look in the menu and on the front-end?
I've just tested it one more time and now it's working as it should. No clue why it wasn't ten days ago. Maybe it was also related to the Elementor update? Well, that's just guessing.
There is no sorting mechanism added in the theme. Does it sort your items on the backend?
Thanks for the feedback!
