How do I get the logo to change color when I hover over the header menu bar?
in Rife Posts: 2
Is there a way to have a company logo change colors when someone hovers over the header menu? The header background on the site I am building is currently transparent. When someone hovers over the menu, I want the background to turn white and our white logo to turn to its normal colors.
I have included a link to a different site that does this so you can see what I am trying to do. The white Bain logo turns red when you hover on the the menu (https://www.bain.com/). I do not see an option for this on Rife Pro. Thanks!
    Welcome :-)
    So what we need from you is:
    1. For a start I will need a live link to your website, so I could check what is your current situation, and what can we use to achieve what you need.
    You are probably using some header color variant, and I need to determine which one.
  • The site is still in development, but you can view it here: http://effectusgroup.com.dream.website/. I have turned off variant because it washes out the white logo when you hover over it. I can turn it back on so you can see the issue.
    OK, great! If you are not using header variant it is even better here, as you can go to
    Appearance → Customize → Header Settings → Type, variant, background → Background color - on hover and set it to your desired color.
    Next about the logo switch, we can add such custom CSS:
    #header:hover .logo.normal-logo {
        background-image: url(http://effectusgroup.com.dream.website/wp-content/uploads/2020/03/effectus-group-logo.png);
    Please implement these changes and check the result.
    If you need to change links as well, you can use this custom CSS:
    #header:hover .top-menu li a, #header:hover  .top-menu li span.title,
    #header:hover .top-menu i.sub-mark {
        color: #000;
