Hi !
I would like to display the category description with the possibility to allow html in it (I would like to show a link saying "go back to".
So, do you know where I can change the file just to display the category description ? And once I get the file changed, can I install a plugin to allow html in category description ?
I can't find any category.php...
Thank you for your help,
Sophie
If you would like to display a category of posts, you can edit the file index.php in the theme directory.
Go to line ~83 and change this
<div class="content-box<?php echo esc_attr( $pagination_class ); ?>">
to:
For me, it seems, that with the active Yoast SEO plugin I can add HTML just fine in the description :-)
