itemscope itemtype="http://schema.org/Organization"
div.logo-conatiner
Thanks for this report!
Could you check if adding
attributes todiv.logo-conatiner
will solve a problem for you?Similar to this answer https://webmasters.stackexchange.com/a/58086
I will also add this fix to the upocming update.
