Google pay button is too wide
in FatMoon Posts: 124
Under a single product page in woocommerce the "google pay" button is huge. It is much wider than the "add-to-cart" button. Is there a CSS for fix?
    It seems this button is as such by nature :-)
    I wonder is there are any settings for it the plugin.
    You can try this custom CSS, but I am not sure if plugin setting will not override it:
    .wc-square-wallet-buttons {
        width: 35%;
    in such case you can try:
        width: 35% !important;
    This works Flawlessly!
    How can I center it? Also, how can i center the "add to cart" button below that?
    You can add such custom CSS:
        margin-left: auto;
        margin-right: auto;
    .woocommerce div.product form.cart .button {
        float: none;
        margin: 0 auto;
        display: block;
    Should center both buttons.
    Flawless! just Flawless!
    Is it possible to remove the wallet button from only single product pages?
    I don't think I see such button on your single product page. I have checked here https://sensibleedibles.com/shop/6-raspberry-hazelnut-bar-v-gf
    Is it there, or should I look somewhere else?
    Sorry but I don't see anything that looks like a "wallet" button.
    Or do you mean to remove the button that we just tried to center?
    Sorry Air, thats exactly what i mean. The google/apple button is what i would like to remove from product page.
    We just centered this button, to hide it now ;-)
    Lets add such custom CSS:
    .single-product #wc-square-digital-wallet {
        display: none;
    Hi Air,
    Thanks. It didn't work. I tried deleting the previous CSS as well. no difference. Thank you.
    3600 x 1080 - 2M
    edited April 2021 Posts: 10,970
    Let's try with stronger rule:
        display: none !important;
    Alright! That worked. Your killing it Air!
