Hi, I have a request. When i set thumbnails enable in album settings, and open an album the thumbnails are visible by deafult , there is a icon underneath that hides & shows them. Can i set it such that the thumbnails are hidden by deafult and user can open them if needed. I like the option to show thumbnails of whats next and previous, but dont what it to overlap the images when album is opened. Thanks
I had tried that but didnt work so i thot it must b for something else, neways i found the problem, accidentally i had in past set that particular album details setting to show thumbnails instead of global. Thanks
Under enabling thumbnails in album you have Show thumbnails/text/none on page load - use it ;-)
PS. Thanks for help with other questions!
