Hi, I want to update Elementor from 3.1.4. to 3.2.2. but before I do this I wanted to ask you about the Compatibility Alert I get: See file attached Can I update Elementor or will there be any incompatiblities/troubles?
If you could hold up 2, 3 more days, I will update Rife Elementor Extensions & Templates plugin as there are some notices displayed with newest Elementor. Not harmful, but better to remove them :-)
Thanks for your question!
Plugin is now updated, so you can get a new version and use it with new Elementor.
Air.
