Slider image dimensions
in PhotoProof Posts: 24
Hi Guys
Finally purchased this theme and starting to edit it, however my images on the slider doesn´t adjust autometically in size as it´s stated in the documentation, see screenshot 1, they look really terrible, so what size should i do them so the whole image is shown in the slider, also when i click on 1 image to see it, the whole image doesn´t show as per screenshot nr 2
Link: https://artbyolivernielsen.dk/
1. Where do i edit and ad a new logo with the name of my page, i mean the "Photoproof" and also the text bottom left corner "PhotoProof Wordpress Theme. Proudly built by Apollo13"
Regards
Oliver
    This is how i want it to look like
    1583 x 790 - 294K
    As for images in the scroller, they are by deafult set as the cover and centered. It is required if you want the "Scroller" effect to not have any holes.
    However, you can try to change it to contain, and check if this result is better for your case.
    Edit the album and in Album details → Album media → Fit images set to Contain do the same for the Fit images - after opening.
    It can create "holes" while scrolling, but maybe not in your case.
    As for logo:
    The footer logo is set in widgets https://rifetheme.com/help/docs/basic-setup/widgets-sidebars/ in the Footer widget area(Header horizontal) .
    As for the header logo it is set in logo settings https://rifetheme.com/help/docs/customizing-the-theme/header/logo/
    However, some logos can be overridden in header color variants: http://rifetheme.com/help/docs/customizing-the-theme/header/variant-light-dark-overwrites/
    Thanks, i do really miss some image dimensions in the documentation, cause when i switch an image on a page, it looks good on the desktop version, but super bad on the mobile version, can i edit the mobile version seperately?
    1. On the contact page, the contact form, there is a slot called "budget" how can i delete this, so i just have a normal contact form? see screenshot
    2, The image scroller on the front page, can i assign links to each image to re-direct to whatever page i want, either when you click on it the first time, or better yet, adding the link after one click one the image once to see the zoom feature and then beeing able to click again to go to another page? see screenshot
    1515 x 737 - 108K
    1583 x 770 - 221K
    Hey there :-)
    If you have more then one case to talk about then please add every case in a separate topic(read more here), cause if this topic will have more then 3 answers, it will make chaos by answering to different points of the first question. I believe you can imagine this :-)
    Back to questions:
    oliver777 said: i do really miss some image dimensions in the documentation, cause when i switch an image on a page, it looks good on the desktop version, but super bad on the mobile version, can i edit the mobile version seperately?
    I want to ask, are you happy with how our demo works on desktop and on mobile here
    https://rifetheme.com/photoproof/ ?
    I understand what you are asking about, but it is impossible to give any image dimensions for such effect as the scroller, when it is also responsive. It all depends on what you want to present.
    oliver777 said: 1. On the contact page, the contact form, there is a slot called "budget" how can i delete this, so i just have a normal contact form? see screenshot
    Forms are created with WPForms plugin, so you can edit it in WPForms → All Forms.
    oliver777 said: 2, The image scroller on the front page, can i assign links to each image
    You can assign link to every image, but it will work on the first click.
    You can do it by editing each image in the Album, as shown here https://rifetheme.com/help/docs/content-management/albums-works-post-types/album-media/
    You can also check this tutorial at 12:08
