Hi, I got this message upon updating. "Scrape nonce check failed. Please try again." And now that file fatmoon/advance/utilities/woocommerce.php is empty and my site is down.
Heyoo! yes, you are right. It was WP cache plugin. Now, can I edit the drop-down menu to exclude "sort by rating", sort by popularity" and sort by the latest"?
I am not sure why we have removed ordering, but it must have been long ago...
It is time for its return.
Please go to fatmoon\advance\utilities\woocommerce.php line ~547
and remove below code I will also add option for this in the next update.
Thanks for asking!
After reinstall you have again removed above mentioned code?
There are few mentions about it across the internet.
I know there are some plugins that enable some changes in this menu.
Like this one https://wordpress.org/plugins/woocommerce-extra-product-sorting-options/
This worked very well. Thank you!
