Mobile/Responsive view "images"
Hi
Every page with an image in header or footer is getting cropped, when i view them on the mobile view. The desktop view looks fine off course but deffinitely not on the mobile view, is that just the way it is, or do i have some options here?
One workaround i´ve found is using different images than on the desktop version, but woud be nice to keep the same images on the pages. It´s pretty much only images in header/top or in footer
    It is normal for background images to make a "background", and due to fixed sizes of images and responsive design, they can get cropped in various screens widths.
    Could you show me an example of such a page so I could see if I can advise anything?
    Sure, i´ve tested with one of the original pictures, see scrrenshot
    640 x 1136 - 198K
    OK, now I think I know what do you mean.
    However, when you add a background in Elementor, you can change how it acts for smaller devices. This way, you will be able to use different types of "coverage".
    I would also check if changing the attachemnt setting to "Scroll", wouldn't help in your case.
    286 x 562 - 56K
    Thanks, however my option to edit pages with elementor has dissapeared from my top bar, usually it´s located where i highlighted it on the screenshot, was the elementor option only available fo a certain time period?
    I havn´t done any edits or anything to have caused this, only thing i´ve done in last days is to edit the plugin "Autoptimize"
    could this have caused it to have been removed from my top bar when i´m logged in? otherwise i find it very weird
    1403 x 409 - 67K
    Various plugins can give different glitches, unfortunately.
    However, I am not sure why you don't see the option to edit with Elementor from the admin bar, but you can always get to it a different way.
    Go to admin panel → Pages → Find your page → Click edit with Elementor.
    749 x 350 - 11K
