I am having a hard time with replacing the fame theme with newer themes that just make things more difficult than it needs to be. Would really like to just swap out the theme and make minor css changes and or updates.
Anyone switch from Fame theme to Fatmoon and have you had any issues? Not sure why the Fame theme was discontinued, it was a good theme.
What issues are you facing exactly with the switch?
Fame and FatMoon themes are not directly compatible, as we had to switch framework meanwhile, but FatMoon was built on what the Fame theme had already.
This means that theme settings might need to be set separately for the FatMoon theme.
Thank you. This is helpful. The issues I faced are mostly layout and navigation related, I will have to manually fix a lot of these which is no problem, I was just hoping to save some time. Your article did recommend similar look alternatives, so I will try those.
Some details why older themes were discontinued are described here https://apollo13themes.com/move-to-new-theme/
All the best and keep up the good work!
