wpbakery update
Since a moment now, I can't update wpbakery, it asks for a license and it's bugging and won't work anymore...
Thank you for your help,
Sophie
  • Hello ?
    Hey Sophie :-)
    I see you wrote again while I was checking your topic :-)
    If WpBakery blocks updating it to the newest version bundled in the theme, please deactivate it, and then follow the normal update procedure.
    1. Deactivate WpBakery plugin.
    2. Go to Appearance → Install Plugins
    3. Update WpBakery from there.
    Hope that helps.
  • Hi !
    Thank you for your answer.
    When I deactivate wpbakery, I go to Plugins (nothing in Appearance) -> Install plugins and all I see is Elementor, not wpbackery. So I reactivated it, and then I go to Install plugin, I update and it says it needs a license.
    OK, I see.
    So in this case, you will have to do a manual update of the plugin.
    Go to this link http://apollo13.eu/temp/wpbakery.zip and download the plugin.
    Next go to your admin panel → Plugins → Add new → Upload plugin → add plugin that you have downloaded from the above link.
    Before doing this, deactivate wpBakery just in case it would block updating again.
    378 x 187 - 6K
  • I worked perfectly. Thanks a lot ! :)
