Hi, i'm customizing my site with Photoproof but any images in the ablums are lost with scroller effect. The names haven't spaces or special chars. The size of unviewed images is the same than the othes, all images are jpg and the orientation is not a problem (i can view vertical and horizontal without problems). Any suggests?
For me, only 1 image didn't load, but I spend 30 minutes trying to load your website at least once. It looks like the server is being overloaded in some way. On the second browser, it loaded all images after the first try, but I waited for the page 3 minutes to start loading.
Do you use some additional script that resizes images? I am asking because it looks like that when I watch links to your images. I suspect it could the reason for all the fails.
1) I can't find any minifung plugin... can u help me? 2) I'd like to have a Category List in wich i can have any other album or subcategories to show. Is it possible?
Could you show me a live link, so I could see what exactly happens?
Be sure to deactivate a "coming soon" mode,if you use one.
https://www.domenicosolimeno.com/album/testap_scroller/
U can see that some images can't load...
BR & TNX
