Discussions
Categories
Home
FatMoon
Theme enhancement options missing
tonicoslo
March 2022
in
FatMoon
I don't have the "Theme enhancement options" in site navigation menu, which should include item icon and "Make this item normal text(will not be link)". Do I need to activate it somewhere?
Air
March 2022
Some plugins override options for the menu.
Try deactivating all plugins and leave only
Apollo13 Framework extensions
active and then check again.
If it appears, activate plugins one by one, until you find a problematic one.
tonicoslo
March 2022
Hi!
So, the problem was that I did not have the Apollo13 Framework extensions installed
Installed it, and now it works like charm.
Thank you!
Sign In
or
Register
to comment.
Sign In
Register
Quick Links
Categories
Recent Discussions
Categories
3.7K
All Categories
114
OneLander
324
PhotoProof
590
Rife
40
Agency
130
Starter
886
FatMoon
197
Thirteen
337
Photon
319
Chillout
769
Hypershot
3
General
March 2022
tonicoslo
March 2022
Air
Discussions
Categories
Sign In
Try deactivating all plugins and leave only Apollo13 Framework extensions active and then check again.
Thank you!
