After updating to Fatmoon 2.4.13 (from versjon: 1.2.2) the posts are missing on frontend when using the post grid element from WPBakery Page Builder (I am using the latest version; 6.8.0).
In the "item design" - "grid element template" I tried choosing both Fatmoon Post and Apollo13 Post, but the result is the same.
Is it not compatible anymore or should I use another element?
I suspect you are facing some JavaScript error and this is why it fails to load.
Could you send me a link to a page where it doesn't; load?
Btw, if I set the item design to Basic Grid: Default, the posts are showing, but without the theme's layout.
Thanks for your help!
Bjorn
