Yes, but it happens only on this server. I suspect there is something special dug somewhere in the code, that triggers this server configuration.
As error "1001" is not documented anywhere really, I don't know which part of the server is in conflict(PHP, database). I will have to do big debugging by switching off parts of the theme on your server.
It will take time, so please give me a few days to test it on your server.
I will get back to you as soon as I will find something.
But the problem I'm facing now is that all the pictures can't be displayed after the installation is complete. you can see it https://kbroliu.com and i have send new acont to you.
thank you help.
What version of PHP did you have previously?
I can see that your server fails to download images from our server like it doesn't accept our SSL certificate or something.
It was 7.4 before
,It is now 7.3.7,thank you.
Sometimes, newer versions of PHP come with better SSL recognition.
I am not really sure, as this is more server stuff, that I am not strong with.
Like I said it would be good to ask a server admin about this.
