After i updated the theme the hide layout option stayed hidden where not needed. However yesterday i noticed the option is visible on all pages. I havent edited anything, the option just appeared out of nowhere. Kindly guide for the same.
Thanks.
http://lucentframes.com/
If you want to set global background, don't do it in every page, do it in
Hypershot theme-> Appearance
. Setting background image also activate hide layout as it was designed for putting some photo there for example. Setting background pattern is set in different location(as said above).With regards.
