Hi, i've 2 questions: 1) Why in my megamenu the space among the raws is higher than the live demo of Template? 2) Can i have a nesting galleries and how?
If you could disable minifing plugin, then it would be easier to debug this, as I suspect that some plugin could be adding some rogue styles to the mega menu.
Currently, I see your website is down, and it can not be viewed. There is a message "Si è verificato un errore critico sul tuo sito web." Please let me know when it will be available again.
lightwords said: For the albums i mean: i'd like to have a "LIST" of categories inwich i can have any categories or ablums...
Could you explain in more detail, what do you mean by this?
Tnx in advance
You can have subcategories in your main categories. Please see https://rifetheme.com/apollo13-framework/docs/content-management/albums-works-post-types/adding-multiple-albums-list-and-album-categories/
In your main category, you can link each album in it to a subcategory.
To link each album to custom link you have to use the "Alternative link" option in each album https://rifetheme.com/apollo13-framework/docs/content-management/albums-works-post-types/album-options/
Now the site is UP... can u try to give me any suggest for Raw's spaces in Megamenu?
TNX in advance
Do you mean that space that was created in the "Archivo" menu? There is 4 column of "menus" while it is set to display 3 columns.
If you mean something else, please mark it on the screenshot.
