Tnx a lot for ur answer... but i'd like to show the albums in RANDOM order and that plugin let me to organize the album in a custom fix order... do u have a solution? Tnx in advance
If you make posts(albums) to show up in random order, you need to know that pagination will be messed up, as well as the lazy load will fail and load albums with duplicates and more.
If you don't plan to use pagination or lazy loading, like when you only have 10 albums, then it could be interesting. Otherwise it creates many problems.
If you still want it, I can post a code changes to achieve it.
If you mean in Albums list mode, then you can use plugin to reorder them https://rifetheme.com/apollo13-framework/docs/plugins-recommendations/post-types-order/
Tnx in advance
