How to delete missing images from HTML code using Elementor theme
My SEO report is reporting that there are links to missing images on https://bethbarkerdesigns.com/about-me-beth-barker-designs/ and these happen to be images that were originally in the theme but which I deleted. They are still in the Media library though.
Can you give some advice on how to delete these broken links? I can't find them in the Elementor page at all.
I've googled this but still not sure what to do and don't want to break the site.
Thanks,
Heather
    Below the section with the title "What we do for you..." you have an invisible section that you will have to delete.
    You can use for this Elementor Navigator to locate this whole section and delete it https://elementor.com/help/navigator/
    Air.
  • Thank you so much! I would never have found this without your help on this! Hope you're both doing well?
