My client wants to remove WSZYSTKO (All) filter on page
https://skrzynecka.eu/i/portfolio/ . In the WordPress Panel under Appearance > Customize > Albums settings > Albums list - Filter, I changed the Default filter to CIĄŻOWE and checked Display "All" filter > Disable. Despite this, page
https://skrzynecka.eu/i/portfolio/ still shows WSZYSTKO (All) filter. What should I more do to make WSZYSTKO (All) filter no longer visible?
Kind Regards,
Arek
Settings that you are trying to change are for Albums list, and what you have on your page is a single album.
Unfortunately, the single album doesn't have an option to turn off the "All" filter due to desi
If you want to keep a single album type, so you can open photos to a lightbox, then I don't have any solution for you.
If however, you will switch to making each photo as a single album then you can turn off opening albums(in each album there is an option for it) and you will have only photos(albums) that you can filter.
Thank you for the answer.
Kind Regards,
Arek
