Discussions
Categories
Home
PhotoProof
ReOrder Album View
lightwords
September 2022
in
PhotoProof
i've used the ReOrder module for change the visualization order of the albums but it doesn't work! Why?
https://www.domenicosolimeno.com/genre/lights/
Tnx in advance for your support
Air
September 2022
Did reorder work on the main albums list page
https://www.domenicosolimeno.com/albums/
What have you used to reorder albums ?
lightwords
September 2022
I'm using Re-Order (that option is present in the Album menu on WP Backend).
Really i don't know "where" i reorder... but all albums sre present in the list...
463 x 503
61K
Air
September 2022
This option comes from the plugin, and you can reorder them by dragging & drop and next clicking "update" at bottom of the screen.
I have just checked and it worked fine for me for the category.
If you are using any cache plugin, then you should disable it, as this may prevent you from seeing the results.
Sign In
or
Register
to comment.
Sign In
Register
Quick Links
Categories
Recent Discussions
Categories
3.7K
All Categories
114
OneLander
324
PhotoProof
589
Rife
40
Agency
130
Starter
886
FatMoon
197
Thirteen
337
Photon
319
Chillout
769
Hypershot
3
General
September 2022
lightwords
September 2022
Air
Discussions
Categories
Sign In
Did reorder work on the main albums list page https://www.domenicosolimeno.com/albums/ ?
