Google font - local load
Apollo 13 Rife 2.4.15
only local font - Google Raleway
Dear support,
because of european law i have followed Your instruction to use google fonts with local files.
https://google-webfonts-helper.herokuapp.com/fonts/raleway?subsets=latin
https://rifetheme.com/help/docs/customizing-the-theme/general-settings/fonts-settings/
In the customizer only raleway is used.
If i have a look in the browser (developer, network, font) i see the fonts loading locally and two fonts loading from google:
Stylesheet - https://fonts.googleapis.com/css?family=raleway:200,300,400,500,600,700|raleway:300,400,500,600,700|raleway:300,400,500,600,700|raleway:700&subset=latin,latin,latin
Font - https://fonts.gstatic.com/s/raleway/v28/1ptug8zys_skggpnyc0itw.woff2
They are found with an external checker too:
https://sicher3.de/google-fonts-checker/
The filename is strange. The family is raleway.
Do you have a clou?
Kind Regards
    Could you send me a link to the website where it happens, so I could check which part of the website loads those fonts?
    In the Customizing → General settings → Fonts settings , you have to set all fonts to normal to Standard fonts, as the theme cannot know that you have overridden fonts location and will load fonts from google anyway.
    Next, you have to set proper fonts for group of elements as explained in in point 7 here https://rifetheme.com/help/docs/customizing-the-theme/general-settings/fonts-settings/#using-custom-font-from-font-file
    Below(in the documentation) you have CSS for a various groups of elements.
  • Thx, its working now. Fonts are loaded locally.
    Does it slow down loading if i set in the customizer-custom CSS all possible raleway font wights?
    /* raleway-200 - latin */ ... /* raleway-300 - latin */ ... /* raleway-400 - latin */ ...
    I believe that each font weight adds to the size of the font to download. However, I also believe that today browsers only download weights that are really used on the website.
    So you should be fine :-)
