Hi, If you scroll down in my woocommerce shop page to click load more products, the products load but without images. https://www.sensibleedibles.com/shop
You don't have to update the child theme. I have just checked and indeed code is in place but somehow it doesn't fire up.
Would you mind if I inspect it on your installation and fix it?
It seems it was cache, as once I logged in, and edited the theme file, it started to work. I have checked in private mode in 2 browsers, so it should be good :-)
Please update the theme, as in the last update this issue was solved.
It is connected to the Jetpack module for lazy loading images, which doesn't fire on its own when you load more items.
I have child theme. Regardless, I updated Fatmoon theme, problem still exists.
Do you have instruction to update child theme?
