Can't add multiple media to a single work
edited November 2022 in Rife Posts: 34
When you click on add images, there is no option to add.
(ad blockers disabled)
Tested on all known browsers.
What to do?
Post edited by Sergey on
    Could you try to disable all plugins except for Apollo13 Framework Extensions, and check there if it acts normally?
    Thanks for your help, problem solved.
    The problem was in the plugin (indicated in the screenshot)
    I'll decide what to replace it with.
    1705 x 709 - 101K
    The problem persisted with another classic editor, what can be done?
    I don't use guteberg at all
    1710 x 689 - 104K
    edited November 2022 Posts: 10,970
    Thanks for the help with this.
    Indeed there was an error in the latest update that made a fix for Gutenberg.
    I will release an update with the fix in a few days.
    Meanwhile, to fix it, go and edit the file in rife/js/admin-script.js line ~1876
    Change this:
    //fires after blocks in gutneberg are ready
    const { select, subscribe } = wp.data;
    const closeListener = subscribe( () => {
        const isReady = select( 'core/editor' ).__unstableIsEditorReady();
        if ( ! isReady ) {
            // Editor not ready.
            return;
        // Close the listener as soon as we know we are ready to avoid an infinite loop.
        closeListener();
        // Your code is placed after this comment, once the editor is ready.
        setColumns();
    to
    if(document.body.classList.contains( 'block-editor-page' )){
            if ( ! isReady ) {
                return;
            closeListener();
            setColumns();
    Clear the cache in the browser(ctrl + f5) and get on with your work :-)
